Monitoring bump stop mod with Atap?
Old Jul 21, 2003 | 04:24 PM
ACCELR8's Avatar
Default Monitoring bump stop mod with Atap?
What Atap parameter should you monitor when you're performing the bump stop mod?
The only paramater that I noticed is the TPS and that is always at 100% when I'm at WOT, even though the TB blade is not at 90 degrees.
Thanks,
Jim
Old Jul 21, 2003 | 06:55 PM
felton316's Avatar
Default Re: Monitoring bump stop mod with Atap?
Dont use AutoTap, it rounds the voltage to the tenths place (not accurate enough). You need to use a digital multimeter.
Old Jul 21, 2003 | 07:33 PM
ACCELR8's Avatar
Where do I get a digital multimeter and how do I use it for this application (i.e., where/how do I hook it up to monitor the voltage)?
Thanks,
Jim
Old Jul 21, 2003 | 07:39 PM
felton316's Avatar
You can get an el cheapo from radio shack for around $10. There is 3 wires from the TPS sensor (1 is ground, 1 is 5V, and 1 is the variable wire). You need to find the variable wire and the ground. Touch the leads to each one and have some one hold the throttle body open. try to get as close to 4.7V without hitting 4.7
Old Jul 21, 2003 | 07:56 PM
ACCELR8's Avatar
Thanks a lot!
Jim
