Need help w/ starting!!
Old Mar 14, 2008 | 11:44 PM
mf2kta's Avatar
Default Need help w/ starting!!
I've searched and looked and can't find what I need.
I had the VATS problem. I bypassed it with the key under the dash, before the steering column. Car ran for a little while, then was running with security light on, then wouldn't start. The key under the dash still has the right resistance. I jumped a wire across the starter relay, nothing. The starter wants to engage like it has a dead battery. I tried switching out the starter and jumping the car, nothing. When I try to start it, it just clicks. The weird thing is the key fob. When I lock it, sometimes is won't honk at all, or will only honk once. When I try to unlock it, sometimes it won't unlock. I'm gonna try to test the BCM tomorrow. Anybody have similar issues?? I could use some help? Thanks!!
