Need a L92 / LS3 Injector Offset Table
I am putting together a 416 inch L92 that will use the L76 intake and injectors. Could someone post an injector offset table for L76 injectors?
This will work, you'll still need to dial in the ve table.
Good Luck!
Thanks, though I believe the numbers you provided are for the IFR table.
I am loking for the injector offset table, that is, the time adder the PCM uses to compensate to the lag in response to injector opening. The values vary widely depending on the injector. Does anyone have a stock L92 or LS3 injector offset table?
