am I too Fuel Rich???
am I too rich of a fuel mixture
at 4500-6000 rpm at WOT sometimes...but not always...any suggestions???free "cut the bottom of the air filter/lid area" to make a bigger intake
MAF porting and descreen
bellows(from home depot)
Pinging up top is usually an indication of being too lean, too much timing, or not enough octane.
Good Luck,
Kevin
If your around .800mv (bank 1 sensor 1 & bank 2 sensor 1), sounds like your way lean.
Go put some Sunoco 94 in the car when you get to 1/4 tank and then check it again...
Lambda reads opposite of onboard 02 sensors. If Lambda reads .800mV then it is too rich. On our onboard 02's, .800mV would indicate a lean condition.
