Pros / Cons to going full-on Speed Density?
Old Mar 29, 2008 | 09:34 PM
M-Ten's Avatar
Originally Posted by Bill Bowling
Yes 1 bar is OK.
Bill
alright cool, thanks. So just take off the MAF and get it tuned to be ran in SD and I'm good to go?
Old Mar 29, 2008 | 09:35 PM
M-Ten's Avatar
and how much of a gain in power do people generally recieve by switching to SD?
Old Mar 29, 2008 | 10:34 PM
foff667's Avatar
LS1TECH Sponsor
0-5 hp or so for most NA applications.
Old Mar 29, 2008 | 10:40 PM
M-Ten's Avatar
Hmm, better than nothing!
Old Mar 29, 2008 | 11:08 PM
foff667's Avatar
LS1TECH Sponsor
https://ls1tech.com/forums/showthrea...145&highlight=
.5 hp in this case
Old Mar 29, 2008 | 11:38 PM
M-Ten's Avatar
Hmm, interesting.. From what I understand, they should be about the same if the tune is right. But if you're pushing high numbers you'll need to upgrade your MAF in order to keep it from being a restriction?
Old Mar 30, 2008 | 12:17 AM
mahhddgtp's Avatar
Ultra retard, newbie, "I don't know how to tune" question...
What's the point of the MAF when it's stock with a 1-bar MAP in a NA setup? If you can run just a 1-bar MAP and no MAF and can run in SD mode... Why didn't GM not just do that from the factory? Why add the MAF?
Old Mar 30, 2008 | 01:03 AM
foff667's Avatar
LS1TECH Sponsor
Emissions & ease of calibration, when the maf does most of the work & you don't need to fine tune a VE table for every rpm/map point its probably a huge cost savings for them in the long run.
-Bill
