Computer chips
Old Jul 26, 2003 | 04:10 PM
PontiacTA99's Avatar
Default Computer chips
Has anyone used the Jet chip,or the Hypertech chip, Do they work? and what kind of power d o you get from them? How hard are they to install?
Old Jul 26, 2003 | 07:11 PM
ZeeQuick's Avatar
Default Re: Computer chips
No chips with our LS1s, programmable computer
Old Jul 27, 2003 | 07:30 AM
They do have chips both Jegs,and Summit racing carry them.
Old Jul 27, 2003 | 11:07 AM
Camaroholic's Avatar
"Chip" is a misnomer. "Module" or "Programmer" would be more appropriate. The chips are NOT removable (like in the 'olden days'). 1993 was the last year of the removable chip for the V8 F-bodies.
IMHO, if your car is not stock, you won't see much if anything from a Jet or an HPP. And I see that it is not stock (they design the things for bone stock or very light mods).
IMHO, the HPP is an expensive fan switch, and the Jet module... well, it's just a sensor tricker.
I personally don't think either is worth the money. If you pick up a used HPP ($150) then maybe. Just make sure it's unlocked.
-Andrew
Old Jul 27, 2003 | 06:08 PM
Cal's Avatar
Cal
I've had a HPP3 and I was just glad I could sell it and get a little money to put towards LS1edit. The PCMs from '94 up use Flash Ram which is re-programable, so there is no need to remove the memory chip to change its contents. I think I've flashed my PCM close to 100 times now. I'm sure glad I didn't have to buy a chip every time I did that!
