Changing injector size with HP Tuners
Old Mar 29, 2008 | 10:21 AM
Apollo0526's Avatar
Default Changing injector size with HP Tuners
I am just finishing up my heads and cam and need to know how to change in HP Tuners the stock injector size to 42lbs. Thanks
Old Mar 29, 2008 | 08:39 PM
ZL1Killa's Avatar
you need the injector flow rate changed. look at my stick in this forum
if you need help with it just PM me
Old Mar 29, 2008 | 09:41 PM
jimmyblue's Avatar
Moderator
Be sure you know what the manufacturer's rating
pressure and your real fuel rail pressure are. You
may have some things to compensate for before
going and changing the value. There are some good
spreadsheets out there for it. The rating pressure
may be hard to dig up (or hard to get one single
straight answer; like the Ford SVO 30s, Ford says
40PSI but have seen many folks saying 3 bar (42ish).
Double check.
Old Mar 29, 2008 | 11:39 PM
Alt's Avatar
Alt
roberts nitrous site shows you
Old Mar 30, 2008 | 10:39 AM
Apollo0526's Avatar
Thanks for the help
