Where to put WBO2 sensor?
Old Apr 3, 2008 | 01:52 PM
BADSZ28's Avatar
Default Where to put WBO2 sensor?
Driver or passenger collector tube? I heard one tends to run a bit leaner than the other so I want to be in the lean tube.
Old Apr 3, 2008 | 01:59 PM
Tootall's Avatar
drivers side, before the cats
Old Apr 4, 2008 | 06:20 PM
Carter01's Avatar
Tootall is right on point!
Old Apr 4, 2008 | 06:53 PM
Randy WS6's Avatar
Mine is on the driver side in front of the header colector, near the stock O2 buns
Old Apr 6, 2008 | 11:50 PM
BigRich954RR's Avatar
why is one side leaner then other. Is it always driver or passger. Mines on the passage should i worry?
Old Apr 7, 2008 | 10:53 AM
BADSZ28's Avatar
I put it in the driver side. That is where the tuner put his when he tuned the car so I should be good. Thanks for the replies.
Old Apr 7, 2008 | 11:37 PM
2002_Z28_Six_Speed's Avatar
If you have the stock exhuast then the cats are different from side to side. That has an effect. Plus, on any car I have ever seen the manifolds just aren't cast the same from side to side. I am sure the exhuast also contributes.
All you can do is tune for one side.
