What to Set MAFT at??????
Old Jul 28, 2003 | 09:08 PM
Ravenous T\A's Avatar
Default What to Set MAFT at??????
Last time I dynoed, my AFR was 13.1 across the board. They said I was running lean. What should my intial setting be on my MAFT(v4.0). I read on here that it should be 6% at WOT. Is this a good setting? I am very very new to this all. My mods are underneath.
Old Jul 28, 2003 | 09:14 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: What to Set MAFT at??????
I would start with +10 base.WOT is hard to guess.
Old Jul 28, 2003 | 10:14 PM
WS6 GreeN's Avatar
Every car is different. Its hard to say where to set it without having AutoTap to monitor with. You say you were running a 13.1:1 AF ratio... If you want to be safe, just tune your WOT 2% RICHER than it is now, and you should be fine. That should put you at 12.9:1 from my experience. Now, if you didnt have the MAFT when you dynoed last time, I would recommend just setting it to 2% rich at WOT and 0 at Base. Hope this helps.
Old Jul 30, 2003 | 06:47 PM
Well i set it at 5% base and 2%WOT. Im gonna buy AutoTap in 2 weeks with the Bi controls. Im gonna go to the track Friday and play with the WOT settings to see if it helps. What should my AFR be for best performance?
Old Jul 30, 2003 | 07:02 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I would have left the base at 0 and added 5% at WOT and tested it at track. I lent a friend my MAF-T, and at the track he kept adding fuel until his performance gain went away. He gained 1mph from adding fuel at wot, and then at one point the car slowed down because it was getting too rich.
Old Jul 30, 2003 | 09:26 PM
K, I'll try that tomorrow and test the WOT at the track. Now lets pray I dont break nuthin like last time!! (aka rearend and tranny on ONE LAUNCH)
