Drive by wire to throttle cable
Old Apr 7, 2008 | 04:37 PM
AKz06's Avatar
Default Drive by wire to throttle cable
Will my 2004 PCU still work with my fast 92mm TB since it is not drive by wire? I read somewhere that drive by wire PCU's cant be used with a cable driven TB, is this true?
Old Apr 7, 2008 | 05:49 PM
Eurospec2's Avatar
Yes, it is true.
There is only 1 car in the US that uses the 1meg PCM with a throttle cable, the 2004 GTO. GM in thier infinite wisdom decided to save some pennys and not install the IAC valve driver into the 1 meg PCM's that were not put in GTO's. If you want to use that throttle body, the PCM will not be able to control the IAC valve
Old Apr 10, 2008 | 06:41 PM
AKz06's Avatar
Default ugh...
So then I need to get another PCU right? Anyone looking for a good PCU to use with drive by wire?
Old Apr 12, 2008 | 12:41 AM
1442's Avatar
yes as a matter of fact i have a pcm that i used before i went to drive by wire we can trade 510 776-1970 james
Old May 7, 2008 | 06:19 PM
AKz06's Avatar
Default Sorry for the wait!
I looked up the service number on the computer they sent me and it actually is not from a 2004! So my comp will work but I appriciate the offer!
Nick
