Dyno Vs Dyno
The dynojet is very simple, it is a known rotational mass (in a unit called slugs) and the acceleration rate is used to determine horsepower. There are no user entered values that will alter power numbers, period. You will be very consistant from unit to unit, and numbers can be compared againste eachother with decent results. The base inertia only dyno's are relatively inexpensive, compared to a mustang dyno.
The mustang dyno, is a load based dyno, with an eddycurrent load cell, based on the values entered into the software, it can read high or low. Typically, if setup correct, (and not broken) they will read 10-15% lower than a dynojet. Since they can be altered, they are hard to compare from unit to unit. These dyno's are much more expensive.
Now dynojet, has a load control unit as well, but the user cannot alter values in the software to alter the power number. This adds significant cost to the unit price.
Ryan
Thing to remember is the only number that really counts is your trap speed at the track, everything else is just a number...
Use a dyno as a tool to see gains/losses in power output, and to see the shape of your power curves, but do not put too much stock in the actual 'numbers', as they dont really mean too much.
Thanks
Mike
Ryan
JOHN D
Thanks
Mike
The mustang dyno's have some great functions, and the way they simulate road load, and power absorption capacity (with dual eddy current units) is nicer than the dynojet with load control. For speed density tuning of high torque cars, this is a true benefit. They can also get RPM based on roll speed, a huge benefit for dynoing diesel trucks, and getting a torque number. (only if you can lock the torque converter, or a manual transmission)
Ryan
Additionally, you can't get an accurate estimate of your track performance using your peak horsepower #, unless you are sitting at that peak hp all the way down the track.
Ryan
Ryan
THANKS AGAIN, check out my car at my shops website in my signature. it is the 05 Yellow Jacket
JOHN D
