Which Wire for EBOOST2 RPM signal?
I've seen the Pin out for 2002 in the conversions, I'm running my dynojet wideband off the CAM position sensor but I'm able to use the .5 multiplier to get the right RPM. The E-boost only has 1-16 and no .5 multiplier. Where hve you guys hooked yours up to?. Ignition coils? Fuel Injector?
Thanks I see it now SOrry Im a dumbass
http://www.ls2.com/boggs/torques/2002pcm.htm
Red connector Pin 10 white wire engine speed signal AKA RPM, I was looking too quickly and seearching for RPM.
