Need Help Firing Up Car (eletrical)
*Deleted ABS Related stuff (cut wiring out etc..)
*Deleted all O2 sensor wiring
*Deleted smog related wiring
*The two boxes under the dash now tick when I connect the battery
*Deleted AC/Heater wiring from engine bay
*Checked the wiring on the coil packs to see if wired properly (they are
grounded and other ends go to PCM)
Any ideas or has someone done something similar and then figure it out? THX.
*Air bag light stay blinking fast even when I pull the key out. Doesn't stop untill I disconnect the battery.
*When I trun the key to on the security, air bag light and the seat belt light flicker fast along with a fast beeping sound.
