AFR at 11.5-11.9 at WOT at 5k rpm
Until i have the money to get hp tuners or ls1 edit I'm using the predator and the LM-1 to tune my car. I was able to get my AFR at 12.5-12.7 in the lower rpm range. But when i get in the upper rpm range i get around 11.5-11.9 AFR. So i leaned it out as much as the predator would let me but it still wasn't enough. Anyone else using the predator has this problem? Also is 11.5-11.9 running to rich. I'm also getiing 1.xx of knock in the upper rpms but none in the lower rpm's.
