is there always going to be some knock retard?
How many GM tuners ignore the knock sensor?
Ford does not use knock sensors on their performance engines, including the factory supercharged ones. I make these systems for many applications, but cannot break through to the Ford community.
As far as I know, none of the Ford guys even listen to a knock sensor on the dyno.
Here's a quote from a Ford tuner, regarding my system:
No, GM does not have individual KR sensors / cylinder.
I would guess that NO tuner would ignore KR data as it's a pretty clear indication that there is something wrong in your tune...
HTH,
-Eagle
From one of the "go to guys" on a Ford forum:
I would appreciate any insight, but please refrain from bashing the Ford guys.
I find that odd. Thank you for that info. Should I ever get a Ford and tune it I will have that in mind.
I mean a non performance low compression motor can knock through out its whole life with no issues as it makes no power. But a performance engine... man I wouldn't run w/o knock sensors in a production performance engine and warranty it!
