maf problem during tune at high RPM
Old Apr 19, 2008 | 07:18 PM
Redbarron's Avatar
Default maf problem during tune at high RPM
Tuner is having problems with MAF signal saying no air flow at high RPMs, says it is dropping off around 5500 RPM. He switched the MAF with one from a low mile 06 and got the same results, anyone else having this issue or know the cause?? He has adjusted the closed loop without a problem. The open loop is causing the problems. this is an EF Live Tune.
So far only hit 370 max HP on a mustang dyno with mods in sig.
__________________
Old Apr 21, 2008 | 11:28 AM
jimmyblue's Avatar
Moderator
Look at the real frequency (scanner and if possible a
DMM that reads frequency). This will tell you if the
MAF itself or its interpreted airflow is the problem.
MAF signal can be corrupted by EMI in the harness,
the Helm book suggests debundling the MAF wires to
check this.
Old Apr 21, 2008 | 04:01 PM
Steel Chicken's Avatar
patch the OS with the MAF patch.
see the detailed responses in your ls1gto.com thread as well.
Old Apr 21, 2008 | 07:45 PM
Redbarron's Avatar
Thanks, will post with results as soon as I know.
