Slow PCM?? is that possible?
My 98 car only logs around 1-2 frames a second, on other cars it is 10 times
as fast with my laptop and cable....
With Edit, it is noticably slower in reading and programming the PCM that
other cars that i also use Edit on...
Can anyone give me a clue as to why? I reflashed the PCM with it making no
difference....
Has anyone ever seen this problem, and can tell me what to do to fix it? Could
this be affecting the Performance of the car any...possibly the PCM is not
"processing" information fast enough... i have been having some serious tuning
issues that i have not been able to work out
THanks
I have noticed that 98's seems to be a tad bit slower.... I will try the slower port speeds and see if that helps
Oddly enough, i dont visit here often and i posted today and when i came back to check my post, i saw your name, but it wasn't my post ...kinda confusing to say the least
Nice name ya have too
I have found an interesting tidbit today
It logs 1.5 frames/sec in normal use, port speeds made no difference
HOWEVER, i turn on the control panel and have it activated while i am logging and i get 6.5 frames/sec
Can anyone explain this craziness to me??
The 6.5 frames per second is the clincher - EFILive automatically drops the scan mode from GM fast dynamic to GM medium dynamic when bi-di controls are active.
You're best option on that vehicle is to use EFILive always in "GM medium dynamic" scan mode.
To do that:
Open the properties window, File->Properties (or hot key: Alt-Enter)
To do that:
Goto the Loggin tab page
Uncheck "Automatically determine scan mode"
Select "GM medium dynamic" from the drop down list
Leave the Dynamic Packet ID at $FE.
Click OK
Now you should see 6.5 frames per second when using 18-24 channels of PIDs.
You should see the following scan rates (approx) depending on the numebr of channels of PIDs selected:
12 fps with 1-6 channels
10 fps with 7-12 channels
8 fps with 13-18 channels
6 fps with 19-24 channels
5 fps with 25-30 channels
4 fps with 31-36 channels.
Note: EFILive Version 6 checks for supported scan modes and automatically picks the best scan mode for the connected vehicle based on the number of PIDs selected.
EFILiveV6 is a free upgrade will be available soon.
Regards
Paul
No matter what you set it to, EFILiveV5 will reconfigure it back to 19200 when it opens the com port.
EFILiveV6 is configurable up to 115200 baud - the com port settings for V6 are configured in EFILiveV6's property window so there should be no need to ever look in the control panel to set the com port settings for EFILive V6.
Paul
Paul, i emailed you a couple of logs to show you the speeds i am/was seeing if you dont care to review them and give me any suggestions you may have.
I guess at this point it is safe to say that my PCM is normal...and doing it's job. correct?
