About to FIRE new motor - Fuel Injector Question
Ok I'm running a Forged 347 LS1 TT setup with 10 lbs boost in my 99 FRC , I pulled the motor to freshen it up and am about to bust it off and a have a quick question regarding my injectors.
I was running Mototron 60 lbs injectors and my tuner scaled them back to 42 lbs and adjusted the pulse width to 11.5 AFR at WOT. I have one injector that is damaged and I want to swap out the whole set for some green top 42 lbs SVOs that I have just to break the motor in with and was wondering if this would be ok or not.
Thanks!
Thanks!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
just get you one 60lb injector... those 42#ers wouldn't work for ANY WOT runs or anything above 550HP and it wouldn't be worth the money to get all the 42#ers and than have to swap again....
whats the point is the way i see it
