DETONATION!! & PREDATOR??
Old 08-04-2003, 03:34 PM
ChazLS12002's Avatar
Default DETONATION!! & PREDATOR??
Is there anyway to read Detonation on a PREDATOR??? If so what could I adjust on the Predator to stop it??
Old 08-04-2003, 05:12 PM
NCal's Avatar
Default Re: DETONATION!! & PREDATOR??
Scroll all the way down to the last output and it should show the amount of KR (Knock Reduction?) the PCM pulled out (in degrees) due to Detonation. KR can be caused by many things, the top 2 being excessive timing and/or lean mixture. The only way to really tune your car right is on a Dyno w/ Wideband O2 feedback.
Nick
Old 08-04-2003, 08:14 PM
MSCLCAR's Avatar
As Ncal said, go into Diagnostics & read the KR all the way at the bottom of Real Time Data. If you have it, try reducing Spark (timing, 5% = 1 degree) & increasing the PE (air/fuel richness, 2.5% = I dunno what). You can check your O2s for a rough estimate of your a/f. Around 900 seems to be right for most cars. Because of my GMAF (?), mine is best around 925 (a/f = 12.6) which I get with + 3.5% PE.
Old 08-05-2003, 02:00 PM
Alright, I drove around watching the Predator, 90% of the time the KR read "0.00" but once in awhile it read up to "2. something" only for a sec. though is this false knock???
Old 08-05-2003, 10:09 PM
NCal's Avatar
I'm assuming that this was at WOT? I'd say it's real. What is your PE & Timing set to?
Nick
Old 08-06-2003, 12:23 AM
PE= 0% and TIMING=9%
The reason why I think it could be false is because I have a fairly stock car TSP Lid, cutout, Magnaflow Catback, and Predator.
Old 08-06-2003, 01:30 AM
NCal's Avatar
A Lid & Cat-back may cause the car to run leaner and in the Texas heat with 9% more Timing, I'd be careful about dismissing it. What MSCLCAR posted above looks like a good plan of action.
Nick
