Thanks!! - VE table adjustment
It still is a little rich at idle, but nothing like it was before. Now its time to hit the dyno for some wideband tuning.
Once the base pulswidth is known then car starts adding in all of the other math, load, performance, emmissions, to adjust the cars fueling.
The Accellerator pump that Cal is talking about is the "tip in" richness that is required to give your car the kind of throttle response you want and stop the car from stumbling with sudden load changes.
When you hammer the throttle your throttlebody opens up and the density of the air inside the manifold changes to atmospheric. Your car is suddenly ingesting air that is much more dense (read more oxygen) than it was previously. To keep up with this sudden addition of oxygen and make the most of it your car uses a "tip in" or "accelerator pump" calculation to suddenly change how much fuel is added to accomodate the additional oxygen.
The accelerator pump calculation is based on volumetric efficiency (or speed density). It uses the predetermine correction factors that we see on the VE table to determine the exact amount of oxygen that the car just ingested. If you have reduced the VE table by a significant amount, the accelerator pump function will not add adequate fuel to deal with the sudden influx of air. The result is that the car stumbles or bogs when you stab the throttle.
Adjusting the VE table is like everything else. As long as you don't go wild, you will be fine.
Good Luck,
Kevin
How much you shift the table is going to be different for every car.
ve made a huge difference in the few cars that i have tuned for drivability. still havent had a chance to tune on the dyno yet since i am just trying to get the OEM drivability back first.
Any Ideas now?
Now if your l-trims are different and are carrying over a bit that could cause a problem, but it should still only be for a bit untill you move into a new cell.
What it boils down to is that your O2's are fixing your part throttle a/f ratio. Do you have splits between your two sides - is it possible you have an exhaust leak anywhere?
Try resetting your computer and seeing if the fix holds for awhile again - if it does it is almost certainly your o2's initiating a fueling change. Have your l-trims/s-trims changed at all?
Suprisingly, with the 2.73 gear I spend alot of time in the 1000-1200 rpm range which I believe adds to the problems. Around town cruising the car stays pretty near 1000 rpm untill I get on the highway or something. Maybe I need to tweak my shift tables to hold it higher before it shifts to the next gear?
My Ltrims are elevated and split at idle, (about +13.3 and +7.8) not sure why they are split but they pretty much even out as I drive. Strims are good (and even).
Do you think Ltrims are my issue? I have messed with all kinds of IAC changes and many different VE table chnages in the 400-1200 range and I'm getting frustrated again. I was gonna try raising the idle some, but I don't think that will help any (idle is at 800rpm in P & D).
Should I try adjusting my IFR table to bring down the Ltrims a little? Would that have an effect on my intermittent surge while stopping issue?
