VE Correction
Old May 4, 2008 | 04:45 PM
GuitsBoy's Avatar
Default VE Correction
Is there any way to log VE correction? Also, are there VE correction cells similar to FTC's?
When I tuned my VE table, I set the VE correction uppper and lower limits to 1.001 and .999 respectively to essentially take VE correction out of the equation. I then re-enabled my MAF and got my fueling inline with the MAF enabled. Now I decided to set the VE correction limits back to stock, and all of a sudden my fueling is completely jacked up. Im hitting AFRs of 18:1 at idle. How can I log VE correction to try and square things up?
Old May 6, 2008 | 02:53 PM
Bill Bowling's Avatar
What software are you using?
Bill
Old May 6, 2008 | 09:01 PM
GuitsBoy's Avatar
Bill
HPTuners, of course
Old May 7, 2008 | 10:31 AM
Jpr5690's Avatar
Cant You Do Lift Tuneing Of Your Ve (with A Disabled Maf)
Old May 7, 2008 | 10:46 AM
GuitsBoy's Avatar
Whats "Lift" tuning??? Never heard of that.
Anyway, the VE table was tuned in SD (MAF Unplugged) with the correction factor effectively disabled (set limits close to 1). I then tuned it using the MAF and got that in line. Then when I set the VE correction limits back to stock, the tune went out of whack.
Old May 7, 2008 | 11:11 AM
Jpr5690's Avatar
Basically You Unplug The Maf And Log Your Long Term Fuel Trims Then Apply Your Lifts Against Your Ve Table ....(this May Be What Your Already Doing)
Old May 7, 2008 | 11:27 AM
GuitsBoy's Avatar
No LTFTs. im running open loop. Im logging via wideband.
But now that I understand what youre saying, yes, im quite familiar with the process. Although may I suggest this to you for future: I find its easier to set your LTFTs to 0 and lock them, then just log STFT averages. Much quicker process, and better resolution, since youre not locked into FTCs.
VE correction is somthing a little more advanced than basic VE table tuning. The correction factor is a multiplier thats used by the ECU to get dynamic airflow and your maf readings to match. Lets say your MAF is telling you that your flowing 2.5 g/sec, but your dynamic airflow reads 2.0 g/sec (based off of VE and rpm). The computer would [supposedly] adopt a VE correction of 1.25. Heres an equation: [Dyn Air] x [VE correction] = [MAF].
My question is that if the VE and the MAF tables were dialed in, why would the VE corection stray so far from 1.000 once it was re-enabled?
Old May 7, 2008 | 03:00 PM
Jpr5690's Avatar
In Theory If Your Ve Is Tuned And Your Maf Is Tuned Shouldent You Have A Correction Factor Of 1?
And If Not Dosent It Just Mean Your Ve Dosnt Match Your Maf (so Just Retune One To Match The Other)
Old May 7, 2008 | 03:06 PM
GuitsBoy's Avatar
Yes, In theory it should.
Apparently thats not the case. The two matched when the correction factor was locked at 1. When I removed the constraints and it the correction factor was now able to move freely between 0.5 and 1.5, the MAF and VE no longer match.
I disabled the MAF again to check my speed density tune, and so far everything seems normal in SD world.
Old May 8, 2008 | 08:23 AM
Jpr5690's Avatar
Well Lets Sit Back And See Whos Got The Answer....(i Sure As Hell Dont)
