Ugh... Did I get a shitty tune?
Here is how the system works: Also, I believe the throttle cable will be the two piece style, pedal to ASM, ASM to throttle body. There will be speed sensors at each rear wheel as well instead of just one at the pinion.
System Description:
Traction control will not have any effect on the operation of the vehicle until the control module detects one or both of the rear wheels rotating faster than the front wheels. At this time the Electronic Brake and Traction Control Module (EBTCM) will request the Powertrain Control Module (PCM) to retard timing. If the EBTCM continues to detect the rear wheel are rotating faster than the front it will request the ASM to reduce the throttle angle. The last measure taken to control the rear wheel is for the EBTCM to apply the rear brakes, thus reducing torque to the rear wheels. Once the rear wheels begin to rotate at the same speed as the front wheels, the system will return full control to the driver. During Traction Control mode, if the brake is applied to only one rear wheel, most of the torque from the engine will be directed to the other rear wheel which will improve the traction of the vehicle.
The braking is accomplished by closing the TCS Master Cylinder Isolating Valve, this isolates the master cylinder from the rest of the system. The TCS Prime valve opens to allow the pump to get brake fluid to build pressure for braking. The drive wheel circuit solenoids are energized as needed to allow for pressure hold, pressure increase, or pressure decrease.
The TCS may be deactivated by the driver if desired. In order to deactivate the TCS with the engine running, depress the TCS On/Off switch. The system will remain deactivated until the ignition switch is cycled, or the switch is pressed again.
System Description:
