Need help!?!?!?!?
Old May 8, 2008 | 08:16 PM
99T/AMAN's Avatar
Default Need help!?!?!?!?
So i have a P0332 code stored, knock sensor bank #2 low input. I searched and people said "oh replace the knock sensors", so i bought a ls6 intake and new knock sensors, cleared code, test drive car 2 key cycles, code comes right back. What should i do now, I am really lost on what to do here guys, I need this code gone. Could it be something with the convertor causing it, is the harness bad, or is the ecm now bad. Please any and all info will help me out.
Old May 9, 2008 | 05:49 AM
99T/AMAN's Avatar
someone, anyone
Old May 9, 2008 | 10:44 PM
vaticano's Avatar
Check the wires. I crushed the wire on mine when I put the intake back on.
Old May 10, 2008 | 12:35 AM
Eurospec2's Avatar
When you changed the knock sensors, did you change the harness as well?
Old May 10, 2008 | 11:36 PM
99T/AMAN's Avatar
no i didn't change the harness is that also a problem?? Oh well not like its that hard to pull the intake back off to replace. If anyone else has any more input let me know. Thanks.
