Predator Adjustments
Old May 13, 2008 | 06:56 AM
8secbusa's Avatar
Default Predator Adjustments
I just installed the 7198 predator tune last night.
Of course, I had to mess with it a bit. I adjusted the trans firmness and speed to +15%. It now chirps 2nd gear, kinda of cool. Will this hurt the trans long term?
Also lowered the fan temp on/off to come in at 180 and off at 175 to try and keep it cooler.
Old May 13, 2008 | 10:20 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
The tranny settings are safe, we won't allow you to exceed certain specs.
Unless you have a 180* stat, those fan settings may be a bit low...
Thanks
Mike
Old May 13, 2008 | 12:37 PM
8secbusa's Avatar
Default Thanks
I have a 160 thermostat in it, so I was hoping to be safe with those settings.
Just out of curiousity, the shift rpm in the tune was set for 6000, is that about 300-500 rpm higher then the peak HP for a stock cammed LS1?
Old May 13, 2008 | 06:41 PM
a338566's Avatar
what temp should the fans be set for w 160 t stat
