Setting upp scanner to log without EIO
Old May 18, 2008 | 12:41 PM
Full-Force's Avatar
Default Setting upp scanner to log without EIO
Im a little confused about the writeup on this.
I used one of the undefined parameters and put the formula in the function box at the bottom. I also named it and gave it an abbreviation name. What I am confused about is what I need to select from the sensor drop down box and the units drop down box.
Old May 18, 2008 | 01:02 PM
foff667's Avatar
LS1TECH Sponsor
Air fuel ratio & afr if im not mistaken.
