ls1 into v6 bird... how to tune
Old May 19, 2008 | 02:54 PM
Dragkid1917's Avatar
Default ls1 into v6 bird... how to tune
So if i throw in my LS1 from my trans am into a v6 firebird. What do i have to do to tune the thing? Is it even possible to use the v6 pcm or do i have to try to take all the electronics and such outof my trans am?
Old May 19, 2008 | 10:06 PM
vdubbing337's Avatar
I am almost positive you would have to do a complete swap wiring harness, pcm and all, I do not see how a V6 pcm could run a V8, you have etra coil packs and extra injectors just for a few problems as well as a different fuel curve.
Old May 20, 2008 | 07:09 AM
bumpin_records's Avatar
vdubbing377 is right,I just did the same thing. you need the computer and harness from a ls1 try to get a 99 and up computer. Im not done. I have to see if i need the dash cluster from a v8 also
