USB to Serial Port Adapters
Old May 22, 2008 | 10:50 AM
Kevin V 2002 SS's Avatar
Default USB to Serial Port Adapters
I have HPTuners and AutoTap, both of which use a serial port connection. My new laptop, with Windows XP, that I bought doesn't have a serial port.
I know people have had issues with adapters before, but I don't know which ones NOT to buy and which ones work well.
Any help is appreciated on what to buy or NOT buy. THANKS!!!
Old May 22, 2008 | 11:07 AM
foff667's Avatar
LS1TECH Sponsor
We recommend keyspan
Black X's Avatar
Keyspan is the HPTuners recommended adapter and worked well for me with XP and the HP Serial cable.
EDIT: Bill you sneaky SOB.... Beat me by seconds.
Last edited by Black X; May 22, 2008 at 11:09 AM. Reason: Bills got mad posting skills
Old May 22, 2008 | 11:13 AM
Where can I buy one???
Old May 22, 2008 | 11:20 AM
foff667's Avatar
LS1TECH Sponsor
http://www.keyspan.com/wheretobuy/
Old May 22, 2008 | 11:57 AM
Thanks!!!!
Old May 23, 2008 | 08:51 PM
gillbot's Avatar
I use a Belkin one from Staples, never an issue.
Old May 23, 2008 | 10:24 PM
koolaid_kid's Avatar
When it comes to these adapters, there are only a few manufacturers of the chipsets involved. But the individual implementation may vary, especially with no-name brands. Stick with a name brand, such as Belkin, and you should be good. Better yet, call the software company of the product you are interested in, and ask them which chipsets (or even adapters) that they support.
Worked in the industry while this transition was taking place, lots of stories here.
Old May 24, 2008 | 10:58 AM
stevieturbo's Avatar
PCMCIA to Serial adaptors work much better. A lot of the USB ones can be troublesome for some reason
Old May 24, 2008 | 08:05 PM
Jake@EPP's Avatar
radioshack ones work pretty good with aftermarket ems's .
as stevie said, the pcmcia adapters work the best.
Old May 24, 2008 | 08:15 PM
Phoenix 5.7's Avatar
never had any problem ever with my keyspan w/ HPT on XP.
Old May 24, 2008 | 10:33 PM
Frost's Avatar
They aren't compliant in their adherence to the 232 standard. They are considered to be loose standards devices. Depending on what they are talking to, it may be a critical portion of the standard for the other device.
Old May 24, 2008 | 10:40 PM
Doc's Avatar
Doc
iomega works for me
Old May 25, 2008 | 12:19 PM
Jake@EPP's Avatar
Good point on this! Somehow i knew you would chime in I need a few gigs of ram for my macbook
Ive had best luck changing a few of the settings as far as aftermarket EMS's go, 9600 usualy is plenty but a few times ive switched to 115,000 and its lightyears faster on datalogging.
I had a cheap one i got from newegg that worked wonders on my megasquirt but when it linked to a DFI or BS3 it was game over, the latency would sky rocket.
