P0106 Code? MAP Problem?
Old Aug 9, 2003 | 05:19 PM
gillbot's Avatar
Default P0106 Code? MAP Problem?
This is the first time i've set this code, any Ideas?
Cam has been in a while and I usually set the Misfire code, not this time......
P0106 MAP/Barometric Pressure Circuit Range/Performance Problem
WTF?!?!?!?!?!
Old Aug 9, 2003 | 05:28 PM
CrazyBosnian's Avatar
Default Re: P0106 Code? MAP Problem?
I've had it for a while...Doesnt seem to affect anything, and no one has still given me a good answer on how to get rid of it...
Old Aug 9, 2003 | 07:46 PM
gillbot's Avatar
Well, mine started idling VERY rough and surging. The SES light came on at the same time my ASR/TCS light went off.
I cleared the code and backed it into the garage, hasn't returned yet.
Old Aug 10, 2003 | 01:18 AM
NoGo's Avatar
The code is set at start-up with large cams.
You can use the VE table tune to eliminate this problem.
Old Aug 10, 2003 | 11:16 AM
gillbot's Avatar
I never threw this code until I did the VE tweak to solve the hotstart issue. That's why I asked in the other thread how to "tweak" the VE properly. What needs monitored, etc...
My posts are here: https://ls1tech.com/threads/showflat...=7&fpart=1
The SES light came on while the car was running after a long sit in traffic. The SES light came on at the same time my TCS/ASR light went off.
More posts here: https://ls1tech.com/threads/showflat...amp;PHPSESSID=
Old Aug 17, 2003 | 08:31 AM
gillbot's Avatar
TTT
