Very fustrating --> whats wrong with my SD tuning
I have painfully aware of that. However, still, no one has been able to answer my original post. I dont care if you have NASA on your side, why did my changes of 10% make no difference in my data logs? Then another 10% change and still no change to FTC 6 in particular. I understand that this is not a linear process; there are several variables that make up the VE value that we are editting.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yes, I am positive, but it is always advisable to double check. My data logs show FTC, MAP, RPM, LTFTs, STFTs, etc. And I know where the divisions are between the FTCs.
First, unless you've rewired the IAT sensor to be separate from the MAF, the PCM doesn't see it when you unplug the MAF. A lack of IAT input will make any attempt at accurate speed density calculations futile.
Second, recording transient data from simply "driving around" gives you lots of misleading measurements. You should really try to take steady state recordings at each speed-load breakpoint in the VE table if possible. This is much easier to do on a load bearing dyno than on the street where you have to worry about traffic, safety, and other unforeseen events.
response -----> My IAT sensor is in the airlid, I have a '99, the MAF and air temp sensor are separate.
Second, recording transient data from simply "driving around" gives you lots of misleading measurements. You should really try to take steady state recordings at each speed-load breakpoint in the VE table if possible. This is much easier to do on a load bearing dyno than on the street where you have to worry about traffic, safety, and other unforeseen events.[/QUOTE]
response -----> That is exactly what I attempt to do when I datalog, I try to keep the PCM in one FTC at a time, during significant steady state driving in mainly FTC 6, 7, 10, and 11. When I can keep the PCM in one FTC for one minute that FTC is fully learned.
And, I take maybe 20 minute drives, while I am doing this, it is long enough to have the pre-dominant FTCs to fully learn.
