New 00 Camaro SS owner Please help w/codes
Hi,
I have an 00 Camaro ss with long tubes, rear o2 sims, xpipe no cats with slp air lid. hen the car starts it takes about 4-5 crnaks to catch. It sounds as if it stumbles at first then it runs strong. I can smell a ruch condition during start up as well as after turning the car off. OK........... the other day it tripped codes P0175(system too rich bank 2) and P0300 (Rnadom Misfire) during start up and at idle. Does anyone know a starting point for me????
Bad o2??? Plugs?? wires??? Any help is appriciated. The initiall cranking of the car should fire right up so the extended crank is buggin me..
Thanks to all inadvance.
Neil
Neil
Id start with a basic tune up. someone can correct me if I'm wrong, but i would say your not getting enough spark/ your plugs are old or fouled, causing the misfire. the multiple cranks would then add too much fuel which would cause the 02 sensor in bank two to read rich.
