Might have tunning issues, PLEASE help.
Old Jun 2, 2008 | 11:30 AM
odarabla's Avatar
Default Might have tunning issues, PLEASE help.
I am going to try and explain what the car is doing and maybe you all can help me figure it out.. Sometimes the car will run fine but others when I start it up the RPMS dip to about 450rpm (normal idle is around 950 rpm). Then it'll idle fine but once I put it in gear it acts like it wants to kill and forget about turning the A/C on. After driving it for a little while it'll run normal but for at least the first 15-20 minutes it wants to or does kill every time I come to a stop or blip the throttle. Could this be in the tune, Or should I start to check other things. The thing that gets me is it doesn't do it all the time. Maybe every third or fourth time I crank up the car. Sometimes this happens worse than others. It's almost like the computer is trying to relearn the tune or something. Thanks for all your help guys.
Old Jun 2, 2008 | 12:17 PM
ZL1Killa's Avatar
its probably in the tune. have a tuner or your tuner or some tuner record and watch all of your idle airflow values and such that affect your car during idle conditions whether cold or hot
