diablosport parameters
Old Jun 4, 2008 | 04:59 PM
02yellowls1's Avatar
Default diablosport parameters
does anyone know or know where i can find the diablosport parameters. i need to do a little modifying for the rear and tire size. so idk how to do that and keep the performance tune in the car.
Old Jun 5, 2008 | 08:06 AM
06MonteSS's Avatar
LS1Tech Sponsor
you would select the same tune as you currently have installed, then select Modify Tune...
make your adjustments, pressing the center enter button to save them, then press the ESC button a couple times, and it will prompt you to "Install Tune now?" select yes, and it will write the changes/adjustments.
here's info on tire size changes:
http://diablosport.com/index.php?mod...e%20adjustment
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jun 5, 2008 | 10:16 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Thanks Lew...
Old Jun 5, 2008 | 03:26 PM
86montecarloss's Avatar
If the user needs custom modifications with complexity above these basic changes he should contact a CMR dealer that can provide a custom tune. Certainly this modification is easily done with the modify tune option. Feel free to contact us at XTREME HORSEPOWER if you need advanced help that requires CMR software.
Old Jun 5, 2008 | 03:35 PM
LS1Tech Sponsor
Awesome, love to see you guys here pushing CMR.
Let me know if you need anything at all.
Thanks
Mike
Old Jun 5, 2008 | 03:43 PM
Blindmelon's Avatar
Will CMR tuning for my Diablo tune out the CEL I get when I replaced my TBSS mechanical to dual electric fans? I also need to now if it can make engine misfire (random) codes less sensitive. I have a built LS2 with L92 heads & 40 lb injectors with a .224/.232 .585/.595 cam at 114 LSA. My A/F is good & my injectors LTFT's look good.
I just keep getting the fan cel & random misfire codes. Thanks
Old Jun 5, 2008 | 04:12 PM
Melon,
The short answer to this is that a patch is required to activate the electric fans along with a modified wireing harness. The only way i know to apply that patch is to send us your PCM so that we can apply the patch and also send your DIABLO SPORT so we can update the files in it. I use a diffrent software program to apply this patch at XTREME HORSEPOWER.
Mike i am not aware of this patch avaliable through CMR can you help with that??
