crank position problems or something car runs bad please read
Old Jun 5, 2008 | 10:09 PM
Travose21's Avatar
Default crank position problems or something car runs bad please read
I have replace the cps and the 02 sensor and put new plugs and now when drive the car it has a misfire when I am driving the car like the car needs gas. then it will have a backfire and cut off. then take awhile to start the it starts up and drive for a minute then do the same thing. misfire and sputter then cut off. I don't know what the hell is the problem I have tried everthing I haveno broken wires no bad sensors and the car is down again someone please post something to help me or call me at 5042284017 travis is the name
Old Jun 6, 2008 | 01:49 AM
1QK-WS6's Avatar
No codes?
Old Jun 6, 2008 | 09:05 AM
Travose21's Avatar
no codes
Old Jun 6, 2008 | 09:19 AM
Frost's Avatar
sent you another PM
Old Jun 6, 2008 | 09:27 AM
Travose21's Avatar
ok got it did you have any problems with the map or maf sensor because some people are telling me to try that also
Old Jun 6, 2008 | 04:18 PM
Travose21's Avatar
Anyone Else Have Any Answers
Old Jun 8, 2008 | 02:26 PM
cablebandit's Avatar
grounds loose on back of head or wires broken IN insulation. My crank sensor wire was broken inside insulation once, idled in driveway for 30 minutes but cut off driving down my driveway.
Old Jun 8, 2008 | 08:37 PM
30th t/a's Avatar
I had a similar problem. if I would jump on it, as soon as it would hit 4000 it would backfire super loud and shut down, 3 seconds later if you start right up and I would drive away. the problem was the crank sensor pigtail. I bought a new pigtail, soldered it in place and it was perfect again....all this after 2 months of trouble shooting.
Old Jun 8, 2008 | 11:48 PM
1966goat's Avatar
I agree.
