HPTuner VCM enhancement issue HELP!!!!!!!!!!!!
Please will apreciate your help a lot.
thanks
Applying a RTT(Real Time Tuning) Custom Operating system and Using it via the VCM Suite Scanner-NEW!
It is you to learn a bit and try to help the guy using this program.
ANd if you have the RTT you can do the changes in the table and inmediately you will observe the changes in the car or wideband without clicking on the botton that says Write Entire?
You can do write calibration instead of write entire; takes 30 seconds vs 2 minutes. But yes, you hook up the wideband, gather data, make changes in the editor, flash the changes to the car and check using the wideband again.
"ANd if you have the RTT you can do the changes in the table and inmediately you will observe the changes in the car or wideband without clicking on the botton that says Write Entire?"
You will immediately see the changes but you still need to write them to the car to take effect permanently.
Check out www.hptuners.com/forum for more help.
