Black smoke from the tail pipes when I nail the throttle from a roll
Old 06-09-2008, 04:12 PM
LS6427's Avatar
Default Black smoke from the tail pipes when I nail the throttle from a roll
What could this be? I was told black smoke means its running really rich. Oil is white smoke, correct?
No smoke if I nail it off the line, only when I'm already rolling (45mph or faster) do I put out a continuous trail of black smoke while I'm on the throttle and accelerating hard from a roll.
I mean a big cloud too. Where I will lose sight of a car just a few lengths behind me.
Can a tune change on its own and run rich?
427ci, ported LS6 heads, LS6 intake, 1 7/8" LT's, dyno tuned 5 years ago.
Old 06-09-2008, 04:18 PM
VinceTrifecta's Avatar
That definitely sounds too rich but it is odd that you'd see it only under certain conditions (e.g. the rolling start).
Have you pulled a plug to see how they look?
Old 06-09-2008, 05:20 PM
LS6427's Avatar
I changed the plugs about 1 month ago, they all looked normal. But even after the new plugs went in it did the same exact thing.
Maybe an Auto Tap would tell me something????
Old 06-09-2008, 06:07 PM
shoemike's Avatar
it will tell you a lot, provided you hook up a WBO2 with it.
it will not be able to make any changes to the ECU though.
Old 06-09-2008, 06:13 PM
LS6427's Avatar
whats a WBO2?
Is that where a wire is hooked up to a bung in the exhaust system a few feet back from where the pipes merge? Because I had one of those put in when I had the car done.
Old 06-10-2008, 10:05 PM
kenp's Avatar
Wide Band oxygen sensor.
