Can Someone Please Post The Average Numbers For...
AFR at WOT:
AFT cruising:
1st fan Temp:
2nd fan Temp:
Timing:
To work with the AFR do i have to turn off the MAF??? OR something like that, i have read something like that.
Where can I find some .bin files for viewing??
thanks
For the fan temps, it depends on what your strategy is. If you're trying to keep the engine as cool as possible, then having the ON temp within 5-8 degrees of the temperature at which the thermostat *opens* (not necessarily its rating) is reasonable, and having the OFF temp 3 degrees cooler then that.
Timing curves can vary wildly depending on the engine, its setup, fuel grade used, elevation, WOT AFR, etc. Generally speaking, at WOT you want to run as little timing as possible, to make the highest amount of power measured at the wheels, with 0-1* spark knock. You need a dyno for this. In the absence of a dyno, you can just tune for 0-1* spark knock, but you won't know if this curve is making the most power.
