PCM
Old Aug 14, 2003 | 08:09 PM
SILVERZZ28's Avatar
Default PCM
I am in need of some help.
My computer went out on my 95 Z28. I purchased a new one. They flashed it, but now when I try to use the LT1 edit, I get the message that it is not a licensed pcm. Any suggestions?
When I communicate with the pcm from LT1 edit, it shows the correct vin at the bottom of the screen. Also, I have a tech1 and it shows my correct vin in the pcm.
Thanks
Old Aug 15, 2003 | 04:10 AM
RedWS6 00's Avatar
Default Re: PCM
Its only a guess, but I expect LS1Edit reads more info from your PCM than your VIN number. There must be somthing else that makes the PCM unique, like a PCM serial number, your LS1Edit is seeing it as a different PCM, I would email LS1Edit and tell them your situation. Hopefully you wont have to buy another licence.
