need help tuning
also how should i adjust the the timing. i know u need to go to the high octane spark table, but what do i do from there(adjust columns or whole table by percentage or certain values.
if anyone out there has similar mods to mine and wouldn't mind sending me a copy of their ls1 edit file, that would be a great reference in my quest for a finely tuned automobile.
if my approach is off. any advice would be a great help
__________________
1998 Camaro SS[list][*]air lid+K&N filter[*]ported MAF[*]shaner 2 throttle body[*]hooker coated headers+ y-pipe[*]ls6 intake[*]tr224 114lsa[*]2002 chrome Z06 rims[*]Yank ST 3500
You need to address the 25% LTerms. Try checking for a vacuum leak by spraying some propane around your intake. Try to get in the back.
Other things to look for are an exhaust leak, bad O2 sensor.
98's suffer from a knock problem. Most likely it is false KR (unless you can hear pinging). Run a search on 98's and KR and you will get plenty of solutions for this problem.
Your timing should be 28-30 above 5200rpm.(the 20 degree's is killing your setup)
i know my timing is low, but how should i change it. i went in and up the values and my timing is still 17-18. i must be doing something wrong.
http://www.ls1.com/forums/showthread...ighlight=Knock
Here are 2 links to get ya started looking for the Knock problem in the 98's
JR
