Tuning for smog test
Old Jun 16, 2008 | 05:54 PM
amit's Avatar
Default Tuning for smog test
hey guys... my car failed the sniffer test and was wondering if anyone has an emmisions tune kickin around? maybe you Cali guys can chime in?thanks
Old Jun 16, 2008 | 08:47 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
At minimum you need to post the specifics of the failed test.
Old Jun 16, 2008 | 09:04 PM
amit's Avatar
ok well here we do a driving test on a dyno for 3.2 km's similiatng normal everyday commuting,.
max allowable for HC is 0.3700 g/km and i got 0.9794. max NOx is 0.9300 and i got 1.1843 g/km
i passed the CO portion of the test. just failed in HC and NOx
Old Jun 16, 2008 | 09:22 PM
gametech's Avatar
That sucks. Normally you either fail HC or NOx, but not both. If it was one or the other, I might know what direction to point you in.
Old Jun 16, 2008 | 09:58 PM
Frost's Avatar
Well, if it failed for both of those I'd look at the cats. The reactions in our converters include two oxidizing reactions to move unburnt HC to water and carbon dioxide, and another to lower nitrogen oxides through partial conversion to nitrogen and oxygen.
Old Jun 16, 2008 | 10:49 PM
2002_Z28_Six_Speed's Avatar
You have headers... Do you have stock O2? Was it tuned with a wideband or 5 gas machine?
Old Jun 17, 2008 | 05:44 PM
amit's Avatar
i have stock o2 sensors and the car was tuned on the dyno
Old Jun 18, 2008 | 10:30 AM
wait4me's Avatar
What is the operating temp of your motor? Is your EGR working?
Old Jun 18, 2008 | 11:07 AM
radkon's Avatar
With the levels you're seeing, its either a dead cat or your tune is way off. 220 on a 114 should pass if the tune is dead on. Start with the VE table then the MAF.
Old Jun 18, 2008 | 05:01 PM
Frost's Avatar
The two I mentioned are what you failed for...
Old Jun 18, 2008 | 05:45 PM
amit's Avatar
I took out the egr and tuned it out..
i have the tsp catted y with prolly just a few thousand miles on em.
i dont think the cat is faulty.. maybe my 02 sensors are garbage and need changin..
Old Jun 18, 2008 | 07:06 PM
99SSragtop's Avatar
I failed all tests and found out it was the cats.
High flow cats have a hard time cleaning up the exhaust.
Switched to stock Ypipe and my car was cleaner than my Altima. 0 on everything NO was 17
Old Jun 19, 2008 | 05:40 PM
amit's Avatar
how much modifying is involved with putting stock y pipe on longtubes?
