First scan with HPT, lots of questions.
Old Jun 19, 2008 | 03:29 AM
Atomic's Avatar
I need a gauge for that
Default First scan with HPT, lots of questions.
First off, this is cool as hell!
Secondly, just got my software installed yesterday but had to go to work so I made a log on the way there just to see whats up.
- To start off, I have a wait4me tune...yea yea yea, all jokes aside it has been good for me until now. I downloaded a stock tune from the bin repository, but when I flashed it to the vcm to play with as a blank slate the truck wouldn't start. After some reading, do I need to do a VATS relearn? The security light has been on, even after flashing back to my inital programming (which works fine). What about the VIN? Do I need to change the downloaded one to mine, or is that a non-issue?
- If you look at my attached log, you'll see as soon as I start moving my O2 sensors are going crazy. I have seen others' logs and theirs are much smoother... I had my rears deleted by Jesse since I have headers and no cats, and in any case they arent attached...whats up?
- At idle and decel, should the TPS be at 7-9 or 0?
- Is there anyway to easily list the maximum, minimum, and average values for the charted objects?
- How does it look overall? Anything glaringly wrong or out of place? Im 24 hours deep in this and having a great time, but I dont yet fully comprehend the big picture of what I'm looking at, but I'm getting there!
Vehicle:
2004 chevy 5.3 LM7
Pacesetter longtubes ORY
Magnaflow muffler, 3" pipe
S&B intake
LS1 fans
thanks!
File Type: hpl
Old Jun 20, 2008 | 09:08 AM
zracer323's Avatar
I'm no expert but i think i can answer a few of your questions.
First off, I would go to HPTuners.com and read their stickies and just start reading stuff over there. That is how I have learned evything I know about tuning.
-Your O2's look fine to me. Thats how mine look when cruising around.
-Your TPS should be at zero when you aren't touching the accelerator not 7-9%
-You can display the average[A], last[L], and count[C] on the charted values on the VCM Scanner
-Overall, it doesn't look too bad. You are getting a little bit of knock, and you fuel trims needs a little bit of tuning but both are easy to tune.
Good luck!
