What are some signs that your O2's are going bad?
My car has 91k miles on it. When I installed headers I didn't replace the 02's. What's some of the signs when your O2's are going bad. Also when cruising do your O2 sensor suppose to read in the 800 because mine jump all around. One second they read 800 then the next second they could read as low as 40 something. One more thing, do you think I could get more out of my car with a custom tune instead of the predator???
Get a custom tune. One of my O2s went bad right after header install. The car ran crappy without a proper tune. I tried hand-helds and mail order type tunes. Don't waist your money. Hundreds of people will tell you the same thing. Are the Pacesetters ceramic coated?
As far as cruising goes, if you have access to HPTuners and look in the bin file, you will find some tables that define the O2 sensor switch points. This has the sensor output in mV (ranges from 351-551 in the stock table I think) over the airflow modes, which are defined in a separate table). This value is the voltage that the computer attempts to center with the STFTs and LTFTs. AFAIK it should represent what GM believes the O2s to output at stoichiometric at each airflow mode on a completely stock car.
LS1TECH & Trucks Sponsor
I would agree to replace them, but not anywhere near that often. We do recommend to replace them but we will make a different recommendation based on each car's use and mod level. Each different operating environment will definitely change the life-span of an O2 sensor. A great bet is to go ahead and replace an f-body sensor when doing headers so you can go ahead and get the vette sensor since it's longer and won't need extensions
We keep most any OEM O2 sensors you could need in stock and the prices are great.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Unless your engine has major issues or you used silcone on your gaskets and contaminated the O2 sensors, they will last from 50-70,000 miles with no degradation in performance or fuel economy, if you want to replace them at 15,000 I am sure that AC Delco, Bosch and Denso appreciate the added income.
