Speedometer help and edit
Old Aug 16, 2003 | 07:23 PM
ChrisV 02 - Z28's Avatar
Default Speedometer help and edit
I just installed a new 4.10 ring/pinion and need to update the speedometer tab in edit. the ? is when i put the new ratio in and hit apply the VSS numbers for pulses per mile and pulses per revolution dont update. so i then checked it on my pc and both numbers did update. so i then checked on a different pc and only one of the vss numbers updated.
Which VSS numbers need to be updated with the ratio swap.
I figure the pulses per mile would, just take stock number * new ratio / old ratio.
not to sure about pulses per revolution.
