Commanded AFR in PE mode question
Old Jun 27, 2008 | 11:27 AM
DaveX's Avatar
Default Commanded AFR in PE mode question
I am working on PE mode for my 99 Z28, which has been migrated to a 02 operating system. I'm using EFI Live. It's a heads/cam/intake/headers car with 30 lb injectors, which I have rescaled the IFR table for. I have done AutoVE a few times and I think my VE table is pretty close. I made a few runs this morning in SD closed loop, and commanded AFR (and actual) is following B3618 as it should (12.75 AFR), until 5600 rpm. Then commanded (and actual) drops to 11.9. About the time it hits 2nd gear, commanded drops to 11.7 and stays there until I let off.
Why does it not stay at 12.75 as I have it set in B3618? Coolant temp was 180 degrees, which puts B3617 (PE modifier based on coolant temp) in a range of 0 adjustment. B3614 (PE modifier based on intake temp) is set to 0 across the board. Is it possible it went into piston protection mode and is using B3659 (commanded fuel when in piston protection mode)? The only possibility I can see here is that it triggered B3652 (piston protection MAF limit), which I have not changed but was not logging at the time, however the MAF was turned off and unplugged.
Please help, thanks.
Old Jun 27, 2008 | 12:43 PM
Doc's Avatar
Doc
Is cat overtemp protection turned on or off?
Old Jun 27, 2008 | 12:48 PM
stevegrizzle's Avatar
I know this is a dumb question but what is your pe table like.......
is it a .87 all the way to 6500 rpms?
Old Jun 27, 2008 | 12:54 PM
DaveX's Avatar
Cat protection (B0701) is turned off. I haven't adjusted any of the other cat protection values. Do I need to?
Steve: my PE modifier based on rpm table (B3618) is set to 12.75 AFR across the board. I plan on tweaking this at the track but it won't do any good if it's not following it. Do I need to adjust PE settings elsewhere?
Old Jun 27, 2008 | 01:24 PM
What about tq limiting......Sounds like its either based on that or vehicle speed.
Old Jun 27, 2008 | 01:49 PM
Gunnar's Avatar
Moderator
Interested to see what you find out. My car is mostly stock (lid/catback) but I have EFI Live with a few tweaks and out of curiousity I logged it a bit last night. Mine did the same thing, ECT was 183 degrees, and rolling into it in 2nd gear it commanded what my table had until ~5400 RPM when it dropped to 11.70 just like yours.
Old Jun 27, 2008 | 01:59 PM
DaveX's Avatar
I think torque limiting is just during a shift, not postive though, or what adjustments it makes. I have removed alot of it though. I think for some reason it's using the piston protection mode table, as it commands 11.70 which is exactly where it goes to. If the storms move out I'm taking it to the track tonight so hopefully I'll get a chance to experiment with it. If nothing else I can try changing the piston protection mode table and see if that corrects it. I did have my maf unplugged, so maybe it defaults to this if it's not getting a signal?
Maybe someone who knows more about it will chime in.
Old Jun 27, 2008 | 02:31 PM
Gunnar's Avatar
Moderator
My MAF is plugged in and functional and it still did it on my car.
Old Jun 27, 2008 | 02:49 PM
DaveX's Avatar
Well that is interesting. I'm not sure what is going on. I'm going to try copying the PE modifier based on RPM table to the piston protection mode table and see what happens. It may be defaulting to this table for another reason. I can't see what else it could be, but I'm still learning my way around this.
Old Jun 27, 2008 | 03:06 PM
^ sounds like you have a good grip on it !
Old Jun 27, 2008 | 03:19 PM
Gunnar's Avatar
Moderator
I'll keep an eye on your thread here to see if that fixes it for you. I'm still pretty new to EFI Live too.
Old Jun 27, 2008 | 03:22 PM
DaveX's Avatar
I'm headed to the strip here in a minute. But it looks like rain. Hopefully it will move on through.
Old Jun 28, 2008 | 08:48 AM
Gunnar's Avatar
Moderator
I looked at my tables last night and 11.70 was actually the value in my "cat protection mode" table, whereas the engine protection was something like 12.9. Don't know if that helps at all, you probably already looked at that table too.
