Maf & Iat Problems
Old Jul 7, 2008 | 09:21 PM
CTS-V LEE's Avatar
Default Maf & Iat Problems
I have a 98 vette cammed boltons....it keeps throwing a high circut iat sensor code....i also have a delphi 85mm truck maf on it and iv tried changin the iat sensor but it still throws a code and runs like crap right now...it runs better w the check engine light on...any guesses how to fix?
Old Jul 8, 2008 | 07:21 AM
69LT1Bird's Avatar
The IAT sensor is built into the 85mm truck MAF. Why are you running a seperate one?
Old Jul 8, 2008 | 09:34 AM
jimmyblue's Avatar
Moderator
High faults are an open circuit somewhere in the
IAT wire-chain. Ground, flaky connector, etc.
Check the connector pins and any adaptor harness.
Use a voltmeter and a needle to probe the IAT
connector wires, ground side should be 0.0V and
signal side a volt or three. Open faults will pull to
5V. You will find your open between the last "sane"
and the first 5V measure-point, just keep narrowing
it down.
