restraint error codes causing SES?
Old Jul 9, 2008 | 12:13 PM
fjb2069's Avatar
Default restraint error codes causing SES?
HP tuners
SES light on. Are the restraint errors causing causing SES? I looked through the DTC's and can not find anything reagrding restraints.
[Restraints] B0017 - RF/Passenger Frontal Deployment Loop (Single Stage or Stage1) Open (History) (Immature)
[Restraints] B0026 - LF/Driver Frontal Deployment Loop (Single Stage or Stage 1)Open (History) (Current) (Immature)
[Restraints] B1001 - Option Configuration Error (History) (Current) (Immature)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Restraints] U1040 - Loss of Class 2 Communications with ABS (History) (Current) (Immature)
[Restraints] U1096 - Loss of Communications with IPC (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Current) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Complete
Secondary Air System: Complete
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: n/a
Old Jul 14, 2008 | 11:15 AM
obi-1's Avatar
I had something similar yesterday. Had the 1096 code and a bunch of other loss of communications. Speedo and tach and HUD quit working. Also told me Door Ajar and all kinds of crazy stuff. But the car ran ok.
Replaced the battery and now everything is fine.
Found the clue on this forum that all kinds of weird symptoms can happen when your battery starts to go bad.
