Shift firmness?
I was able to get it to shift better, but it was too much. It would bark the tires (new Nittos) when shifting while just driving around normally, especially bad when going around corners.
Here's the table I was tweaking the most (it's stock in this pic).
I set all tables from 180 ft lb down to stock and it would still do it when driving around (<25% throttle) and it would still do it.
From what tables on up are included in the normal WOT threshold?
I want it to shift hard at WOT, but not when driving normally. How do you guys normally do this? The car has a few bolt ons and a 3.42 rear end.
For now I just set them back to stock until I can figure something out.
Thanks for the help.
-Casey "I <3 T-56's" Spears
I see all the pressure settings are changed, just about every table. Does it have a shift kit?
I built my trans, I changed a few things in that table above, minor changes in the desired shift time, and the upshift pressure modifiers. Thats all I changed.
My trans shifts more firm as power increases.
I made changes in only areas that needed it, I never needed to scale a whole table.
We were running out of time, so I just reset the trans tables back to stock and he went back home. The only stuff that should be changed from stock is the shift points/etc. I used the new gear ratio/autoscale feature to change that. I also left the TCC Max/Min changed to 100/90 going by what I've been reading on HPTuners forum.
In case anyone is wondering, shifting is firm (but not tire chirping firm) on normal driving, but the deeper into the throttle you go, the harder it gets. It holds in gear a tad longer than stock, shift times are much quicker, and TCC works wonderful.
RickyMartinZ28@aol.com
That'd be sweet.
-Rick
On your dash do you have PRNDL above the steering column and square vents? I've been looking and it seems most of that year have round vents and gauges...
-Rick
