Fuel Injector offset question
Old Jul 21, 2008 | 11:59 AM
Crowder's Avatar
Default Fuel Injector offset question
does hp tuners have a fuel injector offset rating for most aftermarket injectors. Such as low impedence and high impedence. Im gonna be using 60 or 65 lb injectors and was wondering if this option was on here to help calibrate for fur comensation thanks. Also what about 3 bar map calibration? is there a certain table for it or what? thanks
Old Jul 21, 2008 | 01:09 PM
jimmyblue's Avatar
Moderator
The tables there, the difficulty is in getting any good
data to populate them with. The offset varies with
pressure and voltage, you'd be lucky to get even a
single point value from manufacturers it seems.
3 bar is a custom OS but that is available for most
vehicles.
