exhaust leaks causing lean codes?
Old Jul 22, 2008 | 02:07 PM
vetteboyc5's Avatar
Default exhaust leaks causing lean codes?
heres my issue.. I did Headers and cam all at one time.
i went straight to the tuner, and had it tuned. I immediately started having problems with p0171, p01074 which is lean on both banks.
The car wont idle on its own when you first crank it up, and You can see where its running rich dumping fuel
I notices both header collectors leak at the slip fit piping....
If i reset the ecu, and start it up, It runs on its own and everything untill it learns the fuel trims, after about 100 miles its back to the same old ****.
Do you guys think this is my issue?
Old Jul 22, 2008 | 02:27 PM
Eurospec2's Avatar
Very well could be, if there are any leaks near the 02 sensor's they will see the free air and interpret it as a lean condition, and dump fuel.
Old Jul 22, 2008 | 02:36 PM
vetteboyc5's Avatar
would that explain my idle problems?
I need to keep the exaust removable, Im thinking about those expensive V bolt clamp setups and weld up the rest of the system..
will that work good?
Old Jul 23, 2008 | 05:30 AM
BLK02WS6's Avatar
Yes, leaks in the exhaust will cause the trims to add fuel and will cause the idle problems you describe... Gotta get it sealed up...
Old Jul 28, 2008 | 06:36 PM
30thtransam99's Avatar
this is a dumb question but do u still have egr hooked up.
Old Jul 28, 2008 | 07:56 PM
defenestrate's Avatar
i'm having the same codes being thrown and i have a small exhust leak, and i do have the egr hooked back up. can this cause a problem? sorry idont mean to hijack but im not having any luck in my threads...
Old Jul 31, 2008 | 09:14 AM
yes it can if the egr valve is stuck open...it will act like a vacuum leak and cause rough idle.
Old Aug 11, 2008 | 09:31 PM
bigsteve311's Avatar
i am having the same codes pop up . but my z doesnt idle rough . still a leak or just my tune has got it throwing these codes
