engine power whilst decelerating
Old Jul 24, 2008 | 07:31 AM
2004tr's Avatar
Default engine power whilst decelerating
LS1/T56 ( 2002 Firebird )fitted into a Cobra Replica
During deceleration with foot off the gas peddle my brakes have to overcome the engine power still trying to drive forward, effectively at tickover (1000rpm).
Is there a way of tuning this out ? or at least reducing.
Would DFCO be worth modifying.
Thanks
Trevor
Old Jul 24, 2008 | 09:07 AM
jimmyblue's Avatar
Moderator
Pull back on the Throttle Cracker airflow which adds
to the base while rolling (base may also be high, the
sum of desired airflows including error in estimating
is what you're motoring on and rolling idle airflow does
not get trimmed like idle).
Old Jul 25, 2008 | 07:09 AM
2004tr's Avatar
Default throttle cracker
Thank you for the quick reply.
I have since found out what throttle cracker is !
My engine is stock, what value(s) should I see in the table and what percentage should I reduce by ?
I understand that the whole table should be reduced looking at a post on HPTuners is that advisable ?
Many thanks
Trevor
