Lean Cruise Options
Here's an '04 GTO PCM:
Also, there's the option of modifying the "Chevy" tunes based on these posts:
https://ls1tech.com/forums/pcm-diagnostics-tuning/646304-anybody-played-leaning-things-out-during-cruise-gas-mileage.html
https://ls1tech.com/forums/pcm-diagnostics-tuning/942278-lean-cruise-tables.html
It seems the most direct path to fire up my LS6 and drive to the tuner appears to be an GTO tune on a 243 PCM and a then receive a custom tune later to get the 400HP back.
Am I on track here? Any foreseeable issues using the GTO base tune?
--JMarsa
Can the GTO tune support DBW?
--JMarsa
If you follow some of the advice from the other thread, you could enable lean cruise in the PCM of your choice (including the CTS-V PCM).
I think the answers to your questions are: no, you cannot use the GTO PCM straight out of the box to control the ETC (DBW) engine but you could if you reflashed it with an ETC-enabled OS and yes it is possible to have lean cruise on that PCM number with the CTS-V OS.
